Fonction de calcul
fr
vco
Contenu du fichier
/* Modnumlib Scicos interfacing function
 * Copyright (C) 2009 Alan Layec
 * This library is free software; you can redistribute it and/or
 * modify it under the terms of the GNU General Public
 * License as published by the Free Software Foundation; either
 * version 2 of the License, or (at your option) any later version.
 * This library is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
 * General Public License for more details.
 * You should have received a copy of the GNU General Public
 * License along with this library; if not, write to the
 * Free Software Foundation, Inc., 59 Temple Place - Suite 330,
 * Boston, MA 02111-1307, USA.
/* vco Scicos discrete VCO block with frequency divider
 * Type 4 simulation function ver 1.0 - scilab-4.1
 * 21 Mars 2007 - INRIA - Author : A.Layec
#include <math.h>
#include <stdio.h>
#include "modnum_lib.h"
#include "scicos_block.h"
 * ys(t)  = cos(wot + phi(t))
 * phi(t) = int(F(u3(t) + w(t))dt)
void vcoblk(scicos_block *block,int flag)
 int i,k;
 double *u1;
 double *u2;
 double *u3;
 double *u__1;
 double *y;
 /*double *y10;*/
 double *w__n;    /* white noise on input */
 double phi__n;   /* phase noise */
 double h;
 double omega;
 double *theta;
 double *theta2;
 double thetay;
 double theta2y;
 double kv;
 double alpha;
 double beta;
 double gamma;
 double sigma;
 double f__u;
 double *err;
 double *err2;
 double cross_val;
 double cross_val2;
 int with_dyncross;
 int with_infunc;
 int with_2evout;
 int with_wnoise; /* white noise on input */
 int with_pnoise; /* phase noise */
 u1 = block->inptr[0];  /* input voltage */
 u2 = block->inptr[1];  /* divider value or phase noise*/
 u3 = block->inptr[2];  /* phase noise*/
 y = block->outptr[0]; /* cos(theta) */
 h          = block->rpar[0];
 omega      = block->rpar[1];
 cross_val  = block->rpar[2];
 cross_val2 = block->rpar[3];
 kv    = block->rpar[4];
 alpha = block->rpar[5];
 beta  = block->rpar[6];
 gamma = block->rpar[7];
 sigma = block->rpar[8];
 with_dyncross = block->ipar[0];
 with_infunc   = block->ipar[1];
 with_2evout   = block->ipar[2];
 with_wnoise   = block->ipar[3];
 with_pnoise   = block->ipar[4];
 /*not needed*/
 /*cnt    = &block->z[0];*/
 theta  = &block->z[1];
 theta2 = &block->z[2];
 u__1   = &block->z[3]; /* last input */
 err    = &block->z[4]; /* last phase */
 err2   = &block->z[5]; /* last phase */
 w__n   = &block->z[6]; /* white noise */
 /* not needed */
 /*phi__n = &block->z[7];*/ /* phase noise */
 switch(flag)
   /* compute output */
   case 6 :
   case 1 : /* get input */
            f__u = u1[0];
            if (with_infunc!=0) {
              f__u = alpha * tanh(beta * f__u);
            /* get phase noise */
            phi__n = 0;
            if (with_pnoise!=0) {
              if(with_dyncross!=0) {
                phi__n = u3[0];
              else {
                phi__n = u2[0];
              /* test on phase noise */
              if ((phi__n >= (M_PI/4))||(phi__n <= -(M_PI/4))) {
                set_block_error(-6);
                return;
            /* compute theta */
            vcoy_c((i=1,&i),&f__u,&h,&omega,&kv, \
                   w__n,&phi__n,err,u__1,&thetay);
            if(with_2evout!=0) {
                      w__n,&phi__n,err2,u__1,&theta2y);
            y[0] = cos(thetay);
            break;
   /* compute discrete state */
   case 4 :
   case 2 : /* get input */
            f__u = u1[0];
            phi__n = 0;
                phi__n = u3[0];
              else {
                phi__n = u2[0];
                return;
              cross_val = cross_val * u2[0];
            /* compute theta, store input, compute err */
                      w__n,&phi__n,err2,u__1,theta2);
              vcoz_c((i=1,&i),&f__u,&h,&omega,&kv, \
                     &cross_val,w__n,&phi__n,err,u__1,theta);
              (*err2) = (*theta2) - phi__n;
              if( (*err2) >= cross_val2) {
               (*err2) = (*err2) - cross_val2;
            else {
            if (with_wnoise!=0) {
              noiseblk_c((i=1,&i),(k=1,&k),&sigma,&gamma,w__n);
            break;
   /* compute date of crossing */
   case 3 : /* get input */
            f__u = u1[0];
            phi__n = 0;
                phi__n = u3[0];
              else {
                phi__n = u2[0];
                return;
            /* compute theta */
            if((thetay) >= cross_val) {
              block->evout[0] = ((cross_val - (*err)) * h) / ((thetay) - (*err));
              if((theta2y) >= cross_val2) {
               block->evout[1] = ((cross_val2 - (*err2)) * h) / ((theta2y) - (*err2));
            break;
   /* finish */
   case 5 :
            break;
   default : break;
